show meter out-of-profile
show meter {metername} out-of-profile {{disabled-ports} ports [portlist | port_group] | global-count}
Description
This command displays the meters that are out-of-profile and the ports that have been disabled as a result of a meter that is out-of-profile. The show screen will display the out-of-profile status and rate-limit counters for both per-port and global meters. Both the per-port and global meter counters and status are an aggregate of the rule based counters and status which includes both ACL and dot1p rules. In addition a screen will display the global out-of-profile count for per-port meters. The global count is used for debugging systems that do not support per-port counters in the hardware. This global counter for per-port meters is an aggregate of the rule based counters which includes both ACL and dot1p rules.
Syntax Description
metername Meter name.
disabled-ports Show the meter out-of-profile status that resulted in disable-port action.
ports Show the meter appllied to a specified port list.
portlist Port list separated by a comma or -
port_group Port group name.
global-count Counter of all the rules (ACL and dot1p) using a per-port meter.
Default
N/A.
Usage Guidelines
None.
#show meter out-of-profile ports ingMeterGrp
Group: ingMeterGrp
Ports: 4-5
Name                       Status         Disabled  Rate-Limit Counter  Port
ingmeter1                 Out of profile  Yes                  1234567  4
ingmeter1                 Ok              No                         0  5
ingmeter2                 Out of profile  No                         0  4
ingmeter2                 Out of profile  No                      1467  5
ingmeter3                 Out of profile  No                         0  4
ingmeter3                 Ok              No                         0  5
This command was first available in ExtremeXOS 16.1.
Platform Availability
